APPLIANCEDUDE1972
#1 Posted : Sunday, October 19, 2014 7:32:56 AM(UTC)
APPLIANCEDUDE1972
ok, so I ordered a new heating element(279838). This dryer has only 2 wires(no orange) so one wire goes to top of thermostat on element. The next wire goes on right male terminal on element. I had an extra jumper wire around that I was going to use. WRONG! The bottom male small terminal on the thermostat is fine. The left terminal on the heating element is FEMALE!! Guess all I need to do is cut the large female terminal off the jumper and put on a male spade?
fairbank56
#2 Posted : Sunday, October 19, 2014 10:28:20 AM(UTC)
fairbank56
Groups: Expert
That will work but I've never seen a female terminal on that heating element. Where did you get it from?
Eric
APPLIANCEDUDE1972
#3 Posted : Sunday, October 19, 2014 9:06:56 PM(UTC)
APPLIANCEDUDE1972
Ok, I will admit it, an idiot I am. Upon closer inspection, it was the female that is connected from the t-stat, i had to do nothing, lol. What a brain fart!
Whirlpool not drying w/ new element (Dishwasher Repair)
by penumbra 1/11/2015 1:48:12 PM(UTC)
new element not working (Oven Repair (including Ranges and Cooktops))
by marceldavis69 2/4/2014 8:17:46 PM(UTC)
Installed new Element, worked for a few days now nothing (Dryer Repair)
by ccissell 1/21/2014 1:06:16 PM(UTC)
New Element , New Thermostats Too? (Dryer Repair)
by kprovost10 1/4/2014 4:47:48 PM(UTC)
New element, thermostats good, No heat (Dryer Repair)
by Taylor8 1/13/2013 3:25:17 PM(UTC)
New Element Will Not Work (Oven Repair (including Ranges and Cooktops))
by WallyJ 1/14/2011 7:32:42 PM(UTC)
dryer wont get hot, new element & therm on element (Dryer Repair)
by Thomas Bronte 11/19/2009 6:32:32 PM(UTC)
new element does not heat (Oven Repair (including Ranges and Cooktops))
by NWF 9/12/2008 7:34:05 AM(UTC)
