I can't get my dishwasher to start. When I hit start, the normal light and the heated dry light stay on and the start/resume light flashes.
Any suggestions?
I had a similar problem a while ago. The input power plug to the control board had worked itself loose from slamming the door shut. It was making intermittant contact. Mine eventually arced to the board and stopped working all together. Unplug the machine before you check this as that wire has line voltage on it.
Worth a look, just a few screws.
