Something happened to my dishwasher. First, it did not start. Second, I got green Clean light flashing and beeping. I have read that it needs to be reset, so I did Normal-Heat Dry-Normal-Heat Dry, the Clean light turned off, but in a few seconds started blinking again.
I tried to turn off the breaker for few minutes, but it did not help.
Any idea what to do next?
Thanks!
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Thanks! I will try the tech sheet to figure out what is the problem!!!
Ok, I got the following error in the beginning: 4-1 6-1 8-1 6-6
Then the dishwasher got water in, but did not spin the washarms (if I hear it correctly) Then I got two error codes at the end of the test: 4-1 and 6-4
What could be wrong, and where do I start?
Thanks!
