gnnbtrn
#1 Posted : Monday, September 29, 2014 3:31:41 AM(UTC)
gnnbtrn
Something happened to my dishwasher.
First, it did not start. Second, I got green Clean light flashing and beeping.
I have read that it needs to be reset, so I did Normal-Heat Dry-Normal-Heat Dry, the Clean light turned off, but in a few seconds started blinking again.
I tried to turn off the breaker for few minutes, but it did not help.
Any idea what to do next?
Thanks!
#2 Posted : Monday, September 29, 2014 3:57:43 AM(UTC)
Parts for KitchenAid KUDE48FXSS4 / - AppliancePartsPros.com
Use the tech sheet to see if you can figure out the error code.
File Attachment(s):
KUDE48.pdf (1,350kb) downloaded 40 time(s).
gnnbtrn
#3 Posted : Monday, September 29, 2014 4:10:27 AM(UTC)
gnnbtrn
Originally Posted by: denman Go to Quoted Post
Thanks! I will try the tech sheet to figure out what is the problem!!!
gnnbtrn
#4 Posted : Monday, October 6, 2014 7:22:24 PM(UTC)
gnnbtrn
Ok,
I got the following error in the beginning:
4-1
6-1
8-1
6-6
Then the dishwasher got water in, but did not spin the washarms (if I hear it correctly)
Then I got two error codes at the end of the test:
4-1 and 6-4
What could be wrong, and where do I start?
Thanks!
Guest (4)
