dsnider77
#1 Posted : Wednesday, September 24, 2014 7:33:30 PM(UTC)
dsnider77
The refrigerator will not defrost. How do I figure out what is causing the problem.
#2 Posted : Thursday, September 25, 2014 1:49:27 AM(UTC)
Parts for ARSE667BC - AppliancePartsPros.com
See the attachment for the tech sheet
Also below is a manual that you may find useful.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...&id=382;t=1411638244
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle, see the tech sheet.
When the fans and compressor turn off, you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the ADC board needs replacing, re: it is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
File Attachment(s):
ARSE667.pdf (251kb) downloaded 5 time(s).
Kitchenaid Undercounter fridge defrost problem KUDF204ESB00 (Refrigerator & Freezer Repair)
by glenn.anderson82@yahoo.com 6/14/2021 6:41:38 AM(UTC)
Trying to Troubleshoot Defrost Problem (Refrigerator & Freezer Repair)
by webenji 3/29/2020 9:21:34 PM(UTC)
Whirlpool Gold gs5shaxnl02 Defrost Problem / Freezer Side too warm (Refrigerator & Freezer Repair)
by Steve_B 4/21/2019 3:03:18 PM(UTC)
Fridge defrost problem (Refrigerator & Freezer Repair)
by Leeowens 12/15/2017 9:14:42 AM(UTC)
Kenmore Eliite refer defrost problem (Refrigerator & Freezer Repair)
by rascalrick 11/28/2016 2:08:19 PM(UTC)
Whirlpool Gold Refrigerator Defrost Problem (Refrigerator & Freezer Repair)
by TheDoctorsCompanion 8/23/2016 12:47:07 PM(UTC)
by Mad_Cow 3/14/2016 7:20:21 PM(UTC)
Defrost Problem Kenmore Fridge (Refrigerator & Freezer Repair)
by smackover 7/14/2015 4:13:25 PM(UTC)
ADC Defrost Problem (Refrigerator & Freezer Repair)
by edscustom 3/21/2015 6:37:37 AM(UTC)
whirlpool side by side defrost problem (Refrigerator & Freezer Repair)
by dermitt3 11/23/2014 4:37:30 PM(UTC)
by jpsims 9/10/2014 2:30:57 PM(UTC)
Fridge Warm and Defrost Problem (Refrigerator & Freezer Repair)
by gmon1001 9/10/2014 10:53:11 AM(UTC)
by goldbergg70 9/8/2014 10:41:41 AM(UTC)
by guysquestion 9/3/2014 5:32:30 PM(UTC)
by hscholz 8/16/2014 12:36:37 PM(UTC)
