Hi folks. My Frigidaire oven model FEFL78CBA did the following:
1. Gave Fault Code F1 2. The oven lock would engage automaticaly 3. Then it would begin beeping. 4. The oven would not heat.
I replaced the EOC and:
1. The Fault Code F1 went away. 2. It began displaying the time again. 3. The beeping stopped. 4. The oven door quit locking itself. 5. It now displays no code. 6. All is normal, except the oven still will not heat.
Temperature probe measures 1,088 ohms at the probe's connector, and 1091 at the EOC.
Thanks in advance, Gil
THIS FORUM IS DEAD!!!!!!! |
