Low Flyer
#1 Posted : Wednesday, September 24, 2014 6:33:17 PM(UTC)
Low Flyer
Hi folks. My Frigidaire oven model FEFL78CBA did the following:
1. Gave Fault Code F1
2. The oven lock would engage automaticaly
3. Then it would begin beeping.
4. The oven would not heat.
I replaced the EOC and:
1. The Fault Code F1 went away.
2. It began displaying the time again.
3. The beeping stopped.
4. The oven door quit locking itself.
5. It now displays no code.
6. All is normal, except the oven still will not heat.
Temperature probe measures 1,088 ohms at the probe's connector, and 1091 at the EOC.
Thanks in advance,
Gil
#2 Posted : Thursday, September 25, 2014 12:24:31 AM(UTC)
Parts for Frigidaire FEFL78CBA Range - AppliancePartsPros.com
Here is a better copy of the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316255333.pdf
Below is a manual which may be useful.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...&id=283;t=1411632553
Sounds like you may have received a defective replacement board.
I am assuming that the oven stays in preheat and never comes ready.
I would unplug the unit and check the wiring from L1 and L2 to the control board and from the control board to the elements.
Also would not hurt to check the elements for continuity.
