hawg28
#1 Posted : Monday, September 15, 2014 5:04:42 AM(UTC)
hawg28
My refrigerator is keeping things cold .It just seems to be shutting on and off more then usuall.
#2 Posted : Monday, September 15, 2014 11:27:12 AM(UTC)
Parts for Frigidaire FPGC21TAW2 Refrigerator - AppliancePartsPros.com
Check your door seals
Make sure they are clean
Get a 2 inch wide piece of paper and place it between the seal and frame.
Then pull it out to check the seal
Work your way around both doors every 8 inches or so.
Check the hinge side of the seal to be sure that it is not grabbing and twisting when the door closes.
A light coating of vaseline or white lithium grease usually fixes this.
Check that the condenser coils at the back are clean and have decent clearence from the wall.
If the unit has an eco switch turn it on.
If you get condensation between the doors then you will have to turn it off.
