My refrigerator is keeping things cold .It just seems to be shutting on and off more then usuall.
Here are your parts Parts for Frigidaire FPGC21TAW2 Refrigerator - AppliancePartsPros.comCheck your door seals Make sure they are clean Get a 2 inch wide piece of paper and place it between the seal and frame. Then pull it out to check the seal Work your way around both doors every 8 inches or so. Check the hinge side of the seal to be sure that it is not grabbing and twisting when the door closes. A light coating of vaseline or white lithium grease usually fixes this. Check that the condenser coils at the back are clean and have decent clearence from the wall. If the unit has an eco switch turn it on. If you get condensation between the doors then you will have to turn it off. |
THIS FORUM IS DEAD!!!!!!! |
