chiefmitt
#1 Posted : Friday, September 12, 2014 3:27:41 PM(UTC)
chiefmitt
When installing new Drum Rollers on a Maytag Dryer, is a lubricant required on the shaft ?
#2 Posted : Friday, September 12, 2014 11:50:37 PM(UTC)
[COLOR="Blue"]When installing new Drum Rollers on a Maytag Dryer, is a lubricant required on the shaft ?[/COLOR]
No but I usually put a drop of oil on the shaft and then spin the roller to work it in.
Any oil will collect lint etc. so one drop is plenty.
Use 3 in one or sewing machine oil.
Do not use WD40.
