When installing new Drum Rollers on a Maytag Dryer, is a lubricant required on the shaft ?
[COLOR="Blue"]When installing new Drum Rollers on a Maytag Dryer, is a lubricant required on the shaft ?[/COLOR] No but I usually put a drop of oil on the shaft and then spin the roller to work it in. Any oil will collect lint etc. so one drop is plenty. Use 3 in one or sewing machine oil. Do not use WD40. |
THIS FORUM IS DEAD!!!!!!! |
