The dishwasher was not heating at all, and when I looked, I noticed the heating element was cracked. I ordered a new one, it still wasn't heating. I checked it with my multimeter and the ohms were reading way high, so I considered it defective and replaced it again. This newest one is still not heating. Could it be something else?
If so, how do I test to see what it is?
Thanks for any help.
Here are your parts. Note that it is for a PLYW5. PLWY6 did not come up. Parts for Whirlpool WDF530PLYW5 / Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet Could it be something else? Yes it could. Unplug the unit and check the hi-limit thermostat. Should be 0 ohms. If OK then check at the control board. P4-4 to P4-3, you should see the heater resistance. If not you have a bad connection/wire going down to the heater/hi-limit. |
THIS FORUM IS DEAD!!!!!!! |
Thanks so much. I really appreciate it.
Originally Posted by: denman  Here are your parts. Note that it is for a PLYW5. PLWY6 did not come up. Parts for Whirlpool WDF530PLYW5 / Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet Could it be something else? Yes it could. Unplug the unit and check the hi-limit thermostat. Should be 0 ohms. If OK then check at the control board. P4-4 to P4-3, you should see the heater resistance. If not you have a bad connection/wire going down to the heater/hi-limit. I know this is an older thread, but hopefully can get an answer. I have the WDF530PLYW5 and have been trying to figure out why it's not heating/drying. Replaced the heating element, didn't work. Checked the hi limit thermostat, still good. Checking the board at P4-4 to P4-3, I have about 20ohms resistance. Is this GOOD? You said "you should see the heater resistance". So what else could it be? Sorry if this is obvious - I'm very limited in my electrical knowledge.
[COLOR="Blue"]Checking the board at P4-4 to P4-3, I have about 20ohms resistance. Is this GOOD?[/COLOR] Yes it is good. Spec is 8 to 30 ohms so you are smack dab in the middle.
[COLOR="Blue"]So what else could it be?[/COLOR] Since the heater si connected directly to the incoming line voltage through two relays odds are high that it is a bad control board.
I would check the thermistor resistance just to be sure it is OK before replacing the board. See the WATER HEATING/HEAT DRY in the strip circuits section of the tech sheet. |
i tested the P4-4 AND P4-3 and i got nothing. It jsut show a "1". The P4-4 and P4-3 are the last 2 connectors on the board to the left, correct? swak6287 attached the following image(s):
Yes these connections are 3 and 4 but yoyu are not checking them correctly.
What you are trying to check is the heater and hi-limit so it is the connector that plugs into this that you want to check.
Take a look at the strip circuits in the tech sheet. |
Ah yes. Duh. Learning as I go. Thank you. I will check that tonight and report back.
Thanks for the advice. I ended up getting a control board on ******** and the dishwasher appears to be fully functional again.
