jen1374
#1 Posted : Sunday, September 7, 2014 11:59:32 AM(UTC)
jen1374
My Frigidaire bottom bake element turns on and glows instantly but the preheat light never goes off and doesnt beep anymore when it reaches the desired temp. The burner then turns off and never comes back on. I have replaced the burner, and shut the power to the range for a while and still the same problem. What can I do now? I can not bake but everything else works!
#2 Posted : Monday, September 8, 2014 1:21:39 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
It does sound like a control board problem.
Does it reach the set-point temperature?
Is it taking longer than normal to reach the set-point temperature?
Does broil work?
Kenmore Gas Dryer wont stay hot (Dryer Repair)
by johnmeyers 2/12/2021 2:05:37 PM(UTC)
dryer wont stay hot (Dryer Repair)
by keithjvb 6/29/2009 4:06:22 PM(UTC)
