leeann72
#1 Posted : Thursday, September 4, 2014 3:03:32 PM(UTC)
leeann72
I have a Kenmore Elite model 59652673201. The freezer seems fine, had a thermometer in that side and it read 0. The refrigerator is warm, moved the thermometer and it says 50 degrees. I do not hear anything running on the fridge side and don't sense any air circulation. I can see a vent at the top, but there is no air movement around it. I'm wondering if that is the spot where the cool air from the freezer comes from? I've read different threads saying that is just to expel warm air. Any help is so very appreciated.
#2 Posted : Saturday, September 6, 2014 1:43:01 AM(UTC)
Parts for Kenmore Refrigerator 59652673201 - AppliancePartsPros.com
The Sears parts site has actual part breakdown diagrams. Unfortunately they do not share theses with other vendors.
Below is a link to a manual.
You will have to join the site and be logged i to be able to down load it.
http://appliancejunk.com...e&id=72;t=1409996078
Since the evaporator/freezer fan is running and you are not getting any cold air into the fresh food side there is a probably a problem with the damper.
freezer fine, fridge warm (Refrigerator & Freezer Repair)
by countryfolks 5/12/2013 6:19:53 PM(UTC)
Freezer fine, Fridge warm (Refrigerator & Freezer Repair)
by vmylor 1/21/2012 12:04:15 PM(UTC)
rFreezer Fine, Fridge Warm- Electronic defrost timer (Refrigerator & Freezer Repair)
by pwsunglass 5/9/2011 1:27:28 PM(UTC)
