The pot/pans LED flashes and the display has (--) . and the unit can not be programmed or start.
Here are your parts Parts for Whirlpool GU2400XTPT3 Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet Have you tried removing power from the unit for a few minutes to see if it will reset? Could be a shorted key. See the tech sheet on how to check the kepad/control panel with a meter. If it checks out OK then I would replace the control board. Still a bit of a gable but your odds are better. |
THIS FORUM IS DEAD!!!!!!! |
