jamie_pancake@yahoo.com
#1 Posted : Thursday, September 4, 2014 10:23:07 AM(UTC)
The pot/pans LED flashes and the display has (--) . and the unit can not be programmed or start.
#2 Posted : Saturday, September 6, 2014 3:37:08 AM(UTC)
Parts for Whirlpool GU2400XTPT3 Dishwasher - AppliancePartsPros.com
See the attachment for the tech sheet
Have you tried removing power from the unit for a few minutes to see if it will reset?
Could be a shorted key.
See the tech sheet on how to check the kepad/control panel with a meter.
If it checks out OK then I would replace the control board.
Still a bit of a gable but your odds are better.
File Attachment(s):
GU2400.pdf (162kb) downloaded 2 time(s).
