guysquestion
#1 Posted : Wednesday, September 3, 2014 5:32:30 PM(UTC)
guysquestion
I have a kitchen aid ksss42ftx03 refrigerator. I think it has a defrost problem. I can't seem to locate the defrost timer. Is it possible that this model doesn't have one?
#2 Posted : Thursday, September 4, 2014 1:57:17 AM(UTC)
Parts for KitchenAid KSSS42FTX03 Refrigerator - AppliancePartsPros.com
See the attachments for some tech data.
[COLOR="Blue"]Is it possible that this model doesn't have one?[/COLOR]
Yes this unit does not use a defrost timer.
See the tech sheet on how to force a defrost cycle to see if the heater comes on.
Be careful to not burn your fingers on the heater.
Be sure that the defrost heater is frozen as it opens just above freezing killing power to the heater.
File Attachment(s):
KSSS42 A.pdf (906kb) downloaded 18 time(s).
KSSS42 B.pdf (1,078kb) downloaded 19 time(s).
guysquestion
#3 Posted : Thursday, September 4, 2014 5:47:25 PM(UTC)
guysquestion
Thanks.. I ran the diagnostic and everything came back normal. I could even see the heating element turn orange and defrost the coil in a minute. Found water droplets on the underside of the fridge after the defrost! Is it possible that the freezer door was left open or something and so much frost built up that the auto defrost was not able to engage? I just can't figure out why it has been frozen over for almost a week and why sometimes I would find the freezer temp to be -9. Any other ideas would be appreciated. Thanks again for all your help.
#4 Posted : Friday, September 5, 2014 3:22:57 AM(UTC)
[COLOR="Blue"]
Is it possible that the freezer door was left open or something and so much frost built up that the auto defrost was not able to engage?[/COLOR]
No.
Defrost would still work though it may take a few defrost cycles to completely defrost the coils.
[COLOR="Blue"] I just can't figure out why it has been frozen over for almost a week and why sometimes I would find the freezer temp to be -9.[/COLOR]
Sounds like it may be a problem with the control board.
I would check the thermistors, see the tech sheet.
I do not think they have anything to do with defrost but I am not 100% sure of this.
If they check out OK then I would replace the control board.
The reasons I say this is.
-9 is too cold so there seems to be a problem with temperature regulation.
If you can force a defrost cycle then you know that the defrost thermostat and the defrost heater are OK therefore all that is left is the control board.
Below is a manual which may be useful to you.
You will have to join the site and be logged in to be able to download it
http://appliancejunk.com...&id=212;t=1409916004
Kitchenaid Undercounter fridge defrost problem KUDF204ESB00 (Refrigerator & Freezer Repair)
by glenn.anderson82@yahoo.com 6/14/2021 6:41:38 AM(UTC)
Trying to Troubleshoot Defrost Problem (Refrigerator & Freezer Repair)
by webenji 3/29/2020 9:21:34 PM(UTC)
Whirlpool Gold gs5shaxnl02 Defrost Problem / Freezer Side too warm (Refrigerator & Freezer Repair)
by Steve_B 4/21/2019 3:03:18 PM(UTC)
Fridge defrost problem (Refrigerator & Freezer Repair)
by Leeowens 12/15/2017 9:14:42 AM(UTC)
Kenmore Eliite refer defrost problem (Refrigerator & Freezer Repair)
by rascalrick 11/28/2016 2:08:19 PM(UTC)
Whirlpool Gold Refrigerator Defrost Problem (Refrigerator & Freezer Repair)
by TheDoctorsCompanion 8/23/2016 12:47:07 PM(UTC)
by Mad_Cow 3/14/2016 7:20:21 PM(UTC)
Defrost Problem Kenmore Fridge (Refrigerator & Freezer Repair)
by smackover 7/14/2015 4:13:25 PM(UTC)
ADC Defrost Problem (Refrigerator & Freezer Repair)
by edscustom 3/21/2015 6:37:37 AM(UTC)
whirlpool side by side defrost problem (Refrigerator & Freezer Repair)
by dermitt3 11/23/2014 4:37:30 PM(UTC)
by dsnider77 9/24/2014 7:33:30 PM(UTC)
by jpsims 9/10/2014 2:30:57 PM(UTC)
Fridge Warm and Defrost Problem (Refrigerator & Freezer Repair)
by gmon1001 9/10/2014 10:53:11 AM(UTC)
by goldbergg70 9/8/2014 10:41:41 AM(UTC)
by hscholz 8/16/2014 12:36:37 PM(UTC)
