Poppy6576
#1 Posted : Wednesday, September 3, 2014 3:31:59 PM(UTC)
Poppy6576
We noticed our oven's clock was flashing and the oven would not work. Also, when we turned a burner knob, the indicator light only burned about half as strong as normal. I went and flipped off the breaker for a couple of minutes, but the problem remained. I then flipped the oven light on and off and the clock immediately stopped flashing and now the burners and oven work fine. Any ideas? Power surge, maybe? Thanks.
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Frigidaire range oven problem... (Oven Repair (including Ranges and Cooktops))
by Cr00zng 4/22/2013 7:58:08 AM(UTC)
GE oven problem (Oven Repair (including Ranges and Cooktops))
by EPPHILLIPS 8/28/2012 4:34:23 PM(UTC)
Frigidaire Range Oven Problem (Oven Repair (including Ranges and Cooktops))
by bgarrett6 1/21/2011 4:59:04 PM(UTC)
GE oven problems (Oven Repair (including Ranges and Cooktops))
by Appdufus 6/30/2009 10:35:20 AM(UTC)
