bnowotny
#1 Posted : Sunday, August 31, 2014 6:59:08 PM(UTC)
bnowotny
When my oven wouldn't heat I removed it and opened up the back to check on things. I discovered that there was a short on the terminal block and the control board mounted to the block was charred. I can find the terminal block to order, but I cannot find the control board that was mounted on the block. Can anyone offer any help? I'm not an expert so I'm also open to any other advise. :)
I'll attach a photo of the terminal block with mounted control board.
Thanks!
Brian
bnowotny attached the following image(s):
#2 Posted : Wednesday, September 3, 2014 1:24:47 AM(UTC)
Part number: AP5803248
Click on the picture for more info.
bnowotny
#3 Posted : Wednesday, September 3, 2014 1:33:18 AM(UTC)
bnowotny
Thanks! Would you happen to know how to remove the connections to the main control board? Just tugging on them is not working and I'm afraid to do much more because I don't want to damage anything.
