When my oven wouldn't heat I removed it and opened up the back to check on things. I discovered that there was a short on the terminal block and the control board mounted to the block was charred. I can find the terminal block to order, but I cannot find the control board that was mounted on the block. Can anyone offer any help? I'm not an expert so I'm also open to any other advise. :) I'll attach a photo of the terminal block with mounted control board. Thanks! Brian bnowotny attached the following image(s):
THIS FORUM IS DEAD!!!!!!! |
Thanks! Would you happen to know how to remove the connections to the main control board? Just tugging on them is not working and I'm afraid to do much more because I don't want to damage anything.
