Timinsf
#1 Posted : Saturday, October 24, 2009 9:55:40 AM(UTC)
Timinsf
The off button for the oven does not work. All other functions seem to work fine. Is there any way to fix this other than replacing the entire control membrane?
#2 Posted : Saturday, October 24, 2009 12:54:49 PM(UTC)
Open the control panel and remove the control panel ribbon cable from the control board.
Check the tracks in the ribbon cable for a hairline cracks using a magnifier.
Clean the connector on the board using an electronics contact cleaner or isopropyl alcohol and a tooth brush. Let the solvent to evaporate before reconnect the cable.
If it would not help then the membrane switch has to be replaced.
If you need the correct part number then post the color of the key pad.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGRA806PSS00 | AppliancePartsPros.com
kitchen aid gas range (display fading) (Oven Repair (including Ranges and Cooktops))
by tlpru 8/30/2014 2:47:15 PM(UTC)
Kitchen Aid gas range - repair suggestions (Oven Repair (including Ranges and Cooktops))
by Rishavy 7/27/2013 8:33:48 AM(UTC)
Kitchen Aid Gas Range will not light (Oven Repair (including Ranges and Cooktops))
by fscel 7/22/2010 12:57:26 PM(UTC)
Kitchen Aid GAs Range (Oven Repair (including Ranges and Cooktops))
by wstirrett 9/21/2008 9:43:06 AM(UTC)
