pup2bruin
#1 Posted : Friday, August 29, 2014 12:27:01 PM(UTC)
pup2bruin
The "burner on" light stays on all the time
#2 Posted : Wednesday, September 3, 2014 1:57:23 AM(UTC)
Here are parts using the given model number.
Parts for JBP350H2WW - AppliancePartsPros.com
I cannot find info on the given model number so please check it.
Also it may shooew up in the Matching Model Numbers section.
Most likely it is a bad infinite switch for that element.
Burner ON light stays lit but burner not working (Oven Repair (including Ranges and Cooktops))
by mkc5869 4/19/2012 6:03:56 AM(UTC)
