The "burner on" light stays on all the time
Here are parts using the given model number. Parts for JBP350H2WW - AppliancePartsPros.comI cannot find info on the given model number so please check it. Also it may shooew up in the Matching Model Numbers section. Most likely it is a bad infinite switch for that element. |
THIS FORUM IS DEAD!!!!!!! |
