jflynn1
#1 Posted : Thursday, August 28, 2014 9:20:27 AM(UTC)
jflynn1
"high temp wash" led blinking. Reset procedure does not work. power off for several minutes does not work. the "normal" cycle led will blink also when I try to reset. The cancel button will also blink when I push that. So I can have high temp wash, normal and cancel all blinking at the same time. cancel goes off when I push start, normal and high temp still blink, then eventually the normal goes off and only the high temp wash blinks. I cannot follow the technical instructions for testing the keypad. I cant figure out how to disconnect and reconnect the thermistor/owi sensor if the door is latched and the console is put back together as the instructions state. I am think I have a bad control panel, or bad element, or bad door latch. don't want to replace them all (especially the element cuz that looks like a lot of work).
water temp from the faucet is good.
jflynn1
#2 Posted : Friday, August 29, 2014 7:02:59 AM(UTC)
jflynn1
Can anyone show me where to find the thermistor/owi sensor. The tech sheet says to disconnect/reconnect 2 times within 6 seconds. I do not know where this part is located.
