socalwriter
#1 Posted : Wednesday, August 27, 2014 4:03:05 PM(UTC)
socalwriter
Pump has 120 volts going the motor, but will not turn pump. I took the pump out so I could see if it was turning, the pump is brand new. I even returned it to get another one, that doesn't work either, even though I have 120 volts going to it.
sidfink43
#2 Posted : Wednesday, August 27, 2014 5:22:14 PM(UTC)
sidfink43
If it really does have the voltage than this is somewhat of a mystery. I can only think that either the pump is jammed inside the housing or that something is blocking the drain hoses either to or from the pump.
Drain pump working intermittently(?) (Dishwasher Repair)
by GRobLewis 6/8/2024 4:45:45 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool heat pump dryers (Dryer Repair)
by Aptmtncguy 1/19/2024 3:44:50 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Bosch ventless dryer sump pump not working (Dryer Repair)
by mdavidson 11/18/2023 2:22:57 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Rheem RQNJ-A048JK000 heat pump (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/16/2023 7:10:38 AM(UTC)
GE GTW330ASK1WW circulator pump and spinn test just does nothing (Washer Repair)
by tommalia@ttdsinc.com 3/10/2023 3:41:31 PM(UTC)
Noisy LG Drain Pump (Washer Repair)
by Guest 1/13/2023 3:19:30 PM(UTC)
drain pump on lid locked (Washer Repair)
by Randero 7/6/2022 5:32:07 AM(UTC)
Maytag 5500 drain/pump issues (Washer Repair)
by mlp141 6/26/2022 7:06:24 PM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Pump for a Kenmore 3.5 super capacity (Washer Repair)
by Guest 4/17/2022 10:34:55 AM(UTC)
