Dom31
#1 Posted : Sunday, August 17, 2014 12:36:49 PM(UTC)
Dom31
My kenmore gas dryer heats for about 10 seconds then stops heating then starts heating again and does the same thing . I replaces the thermal fuse a couple months ago when that went out . And now this is the problem I'm having . So I just replaced the thermistor and the coils and the Igniter and still have the problem .
ggarnett
#2 Posted : Saturday, October 17, 2015 1:01:42 PM(UTC)
ggarnett
Did you ever get an answer on this? I have the same problem. Kenmore Elite HE3 (11092826102). As far as I can tell, everything checks out:
no venting clogs
coils replaced
thermistor replaced
high limit thermostat checks out
flame sensor checks out
I'm guessing it's not the moisture sensor or that loop since the dryer behaves the same on timed dry cycles? As far as I can tell the moisture sense is checking out anyway. Mother board?
Help!
