AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer heats for 10 seconds then stops heating then starts heating again
My kenmore gas dryer heats for about 10 seconds then stops heating then starts heating again and does the same thing . I replaces the thermal fuse a couple months ago when that went out . And now this is the problem I'm having . So I just replaced the thermistor and the coils and the Igniter and still have the problem .
Did you ever get an answer on this? I have the same problem. Kenmore Elite HE3 (11092826102). As far as I can tell, everything checks out:
no venting clogs coils replaced thermistor replaced high limit thermostat checks out flame sensor checks out
I'm guessing it's not the moisture sensor or that loop since the dryer behaves the same on timed dry cycles? As far as I can tell the moisture sense is checking out anyway. Mother board?
Help!
Dryer Repair
