The doors on my double wall ovens don't close fully; I use tape to keep them shut. Repair man wants $400 to replace hinges on both ovens! I want to try to do it myself but online all I can find is "Hinge Receptacle 701039" as a replacement part. Don't i need the part that hooks into the receptacle too? Can anyone tell me what part /parts I need and how to replace them? many thanks!
Below are apart that may work. Click on the picture to get more info on it and read the Q&A. Then call the parts people at AppliancePartsPros to confirm that this part will fit your unit. Part number: AP4363956
[COLOR="Blue"] Don't i need the part that hooks into the receptacle too?[/COLOR] Yes I would say that the hinge itself is the problem unless you can see a problem with the receptacles. Hopefully you have the operators manual, that should tell you how to remove the doors. Often just removing them and re-installing them will fix this problem. |
THIS FORUM IS DEAD!!!!!!! |
THANK YOU!! will try it with those hinges. i appreciate your help!
