MCLP
#1 Posted : Sunday, August 3, 2014 9:24:29 AM(UTC)
MCLP
The doors on my double wall ovens don't close fully; I use tape to keep them shut. Repair man wants $400 to replace hinges on both ovens! I want to try to do it myself but online all I can find is "Hinge Receptacle 701039" as a replacement part. Don't i need the part that hooks into the receptacle too? Can anyone tell me what part /parts I need and how to replace them? many thanks!
#2 Posted : Thursday, August 7, 2014 7:35:59 AM(UTC)
Below are apart that may work.
Click on the picture to get more info on it and read the Q&A.
Then call the parts people at AppliancePartsPros to confirm that this part will fit your unit.
Part number: AP4363956
[COLOR="Blue"]
Don't i need the part that hooks into the receptacle too?[/COLOR]
Yes I would say that the hinge itself is the problem unless you can see a problem with the receptacles.
Hopefully you have the operators manual, that should tell you how to remove the doors.
Often just removing them and re-installing them will fix this problem.
MCLP
#3 Posted : Thursday, August 7, 2014 10:01:21 AM(UTC)
MCLP
THANK YOU!! will try it with those hinges. i appreciate your help!
