Only the bottom part of the Freezer and Fridge is cold.
Remove the freezer back panel and describe the frost pattern.
Also does the evaporator/freezer fan run?
It should be on when the compressor is on. One caveat is that there is a delay just after e defrost cycle.
I am off to the cabin for a couple days so will not be available. Richappy should be able to give you any additional help if you need it. He knows a lot more about fridges than I do. |
THIS FORUM IS DEAD!!!!!!! |
