Whirlpool Gold gs6shexnb00 Compressor cycles on, runs 7 seconds, off 2.5 minutes. Both fans work at all times. Capacitor - pulls .09 amp while compressor is engaged. Compressor - pulls between 16 to 18 amps on L and N for the entire 7 seconds. Ohm - 4 7 11, 0 to ground. Didn't notice anything burnt. Start device does rattle when shaken. compressor sounds OK. 74992300.pdf (450kb) downloaded 8 time(s). WED5300.pdf (96kb) downloaded 11 time(s). MER5752.pdf (347kb) downloaded 123 time(s).![bimetl-def.jpg bimetl-def.jpg](/resource.ashx?p=7346&b=1) ![IMAG0063.jpg IMAG0063.jpg](/resource.ashx?p=7347&b=1) AFD2535.pdf (243kb) downloaded 4 time(s).Russell D H attached the following image(s):
Replace the start device, order it on this site.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Replace the start device, order it on this site. Thank You very much!
Results... Runs like new. Shipping... Ordered Friday, arrived Wednesday. FedEx ground from California to Kentucky. Would be 3 business days for delivery. Not Bad :)
