Whirlpool Gold gs6shexnb00 Compressor cycles on, runs 7 seconds, off 2.5 minutes. Both fans work at all times. Capacitor - pulls .09 amp while compressor is engaged. Compressor - pulls between 16 to 18 amps on L and N for the entire 7 seconds. Ohm - 4 7 11, 0 to ground. Didn't notice anything burnt. Start device does rattle when shaken. compressor sounds OK. 74992300.pdf (450kb) downloaded 8 time(s). WED5300.pdf (96kb) downloaded 11 time(s). MER5752.pdf (347kb) downloaded 123 time(s). AFD2535.pdf (243kb) downloaded 4 time(s).Russell D H attached the following image(s):
Replace the start device, order it on this site.
Originally Posted by: richappy Replace the start device, order it on this site. Thank You very much!
Results... Runs like new. Shipping... Ordered Friday, arrived Wednesday. FedEx ground from California to Kentucky. Would be 3 business days for delivery. Not Bad :)
