Freezer frozen at back. I have already checked defrost heater and defrost thermostat. Both checked good. I noticed that the fan runs off and on. On for about 3 to 5 minutes then off. I was thinking it was the freezer thermostat. I wanted to make sure before I ordered it. Could it be the defrost control board. The fan spins freely.
Here are your parts includes a wiring diagram. Parts for Frigidaire FRS26KF6CW4 Refrigerator - AppliancePartsPros.com[COLOR="Blue"]I was thinking it was the freezer thermostat.[/COLOR] Only if the compressor and it's fan also turn on/off. [COLOR="Blue"]Could it be the defrost control board. [/COLOR] Yes it could be. [COLOR="Blue"]The fan spins freely.[/COLOR] You cannot tell if the fan is good just by giving it a spin. You have to check the power across it. If you get 120 volts and it stops then it is a fan problem. |
THIS FORUM IS DEAD!!!!!!! |
