acguyin05
#1 Posted : Monday, July 28, 2014 5:48:42 AM(UTC)
acguyin05
Freezer frozen at back. I have already checked defrost heater and defrost thermostat. Both checked good. I noticed that the fan runs off and on. On for about 3 to 5 minutes then off. I was thinking it was the freezer thermostat. I wanted to make sure before I ordered it. Could it be the defrost control board. The fan spins freely.
#2 Posted : Monday, July 28, 2014 11:48:48 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Frigidaire FRS26KF6CW4 Refrigerator - AppliancePartsPros.com
[COLOR="Blue"]I was thinking it was the freezer thermostat.[/COLOR]
Only if the compressor and it's fan also turn on/off.
[COLOR="Blue"]Could it be the defrost control board. [/COLOR]
Yes it could be.
[COLOR="Blue"]The fan spins freely.[/COLOR]
You cannot tell if the fan is good just by giving it a spin.
You have to check the power across it.
If you get 120 volts and it stops then it is a fan problem.
