FastNinety
#1 Posted : Friday, July 25, 2014 7:44:58 AM(UTC)
FastNinety
Service person just left house.
Display panel went put on Whirlpool oven.
Used oven last night
Set temp for 380, checked back 20 minutes later, temp was only 225.
Display panel blank.
Shut oven off, display panel still blank.
About 10 minutes later display panel came back on.
He stated display pane(board)l no longer available, was made in Japan.
Factory was next door to nuclear plant that blew up.
Fact or fiction???
After reading how bad whirlpools are I might just buy a new wall oven, but I need to find out it story I was told is TRUE.
#2 Posted : Friday, July 25, 2014 9:20:47 AM(UTC)
Your model number is incomplete, please check it.
FastNinety
#3 Posted : Friday, July 25, 2014 10:55:48 AM(UTC)
FastNinety
Whirlpool RBD305 Built-in Electric Oven
#4 Posted : Friday, July 25, 2014 12:45:26 PM(UTC)
Sorry but I still cannot find any info on just RBD305.
Find your model number - AppliancePartsPros.com
Below is what comes up at AppliancePartsPros.
There is a list of this series of units in the Matching Model Numbers section.
Parts for RBD305 - AppliancePartsPros.com
FastNinety
#5 Posted : Friday, July 25, 2014 12:53:22 PM(UTC)
FastNinety
Am on the phone with
whirlpool now. With the correct model #RBD305PRS00.
The part is available.
Thanks for your time
Don
#6 Posted : Saturday, July 26, 2014 2:03:53 AM(UTC)
Parts for Whirlpool RBD305PRS00 Wall Oven - AppliancePartsPros.com
Could be that the control thermal fuse is blown.
This is usually up close the the control board and looks like a little torpedo in the wire.beklow is an example.
It does not show up in the parts but that is not unusual.
If it is blown you will need to call for the correct part number.
Note that there will not be a visual indication that it has blown.
Part number: AP3777386
File Attachment(s):
RBD305.pdf (505kb) downloaded 1 time(s).
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
Vintage Wall Oven SIZES (General Talk)
by sabfre 12/21/2023 8:52:31 AM(UTC)
GE Monogram Electric Wall Oven Model No. Z EK938SM1SS (Oven Repair (including Ranges and Cooktops))
by Govtman 11/14/2023 7:24:46 PM(UTC)
Kenmoore wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 6/23/2023 1:46:47 PM(UTC)
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Gaffers and Sattler wall oven 1970-1980 models (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 2:45:52 PM(UTC)
Determining voltage for 1960s GE-J-720 wall oven install (Oven Repair (including Ranges and Cooktops))
by Austo1989 2/22/2023 4:33:49 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Old GE Double Wall Oven - Top isn't working (Oven Repair (including Ranges and Cooktops))
by Doubletheoven 11/25/2022 5:19:46 AM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
