schippy
#1 Posted : Tuesday, July 15, 2014 7:59:19 AM(UTC)
schippy
The left two burners are the simmer burners. One has been out since we moved in 2 years ago and the second just went out. All other burners work fine. When I turn the knob there is no spark or gas on these two burners. However if I turn any of the other burners to light them these two burners spark. So the spark mechanism works. In doing research I think it might be the potentiometer. My question is though since I am not getting any gas from these two burners as well if the potentiometer goes bad does it stop the selinoid from openeing and releasing gas??? If so then sounds like I just need to change the potentiometer. Someone told me it might be the whole simmer controller that needs to be replaced. Thoughts????
Thank you
schippy
#2 Posted : Tuesday, July 15, 2014 12:36:18 PM(UTC)
schippy
Someone sent me the repair book for this model and it shows the simmer control module under the toe panel. I took off the toe panel and everything else in the diagram is there except the simmer control module. Any ideas where it might be?
