Jeremyh
#1 Posted : Friday, October 23, 2009 4:23:18 PM(UTC)
Jeremyh
I have a Frigidaire upright freezer that is not freezing. It is cold inside, about refridgerator temp, but doesn't freeze. The coils are frozen.
#2 Posted : Friday, October 23, 2009 5:31:00 PM(UTC)
Replacement parts for FRG FFU20FC6CW1 | AppliancePartsPros.com
First make sure tha evaporator motor is running.
If OK remove the evaporator cover so you can see the coils etc,.
Looks like the defrost times is at the back of the unit at the bottom.
Turn the defrost timer cam till the compressor evaporator fan shut off.
You are now in defrost mode.
See if the heater heats up.
Be careful do not burn your fingers.
If it does heat up then replace the defrost timer.
If it does not heat up it could be the defrost heater itself of the defrost thermostat.
Below are a couple good sires with additional troubleshooting help.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Upright freezer problem (Refrigerator & Freezer Repair)
by brobriffin 11/20/2014 3:31:42 PM(UTC)
Frigidaire upright freezer problem (Refrigerator & Freezer Repair)
by stephen01 11/19/2013 1:08:44 PM(UTC)
Fridgidare Upright Freezer Problem (Refrigerator & Freezer Repair)
by mmm26815 1/29/2013 5:38:25 PM(UTC)
