cjaldous
#1 Posted : Monday, July 14, 2014 11:28:14 AM(UTC)
cjaldous
I woke up yesterday to find that my freezer was half thawed. The evaporator fan was not spinning.
I opened the evaporator compartment and found the top portion iced up, but the fan could spin freely.
After unplugging the fridge, and doing some troubleshooting (see below) I plugged the fridge back in and the fan started working.
The freezer got cold enough to freeze ice, and everything seemed to be working.
I woke up this morning to find the evap fan off again, the freezer half thawed, and the same iced up top coils.
Here's the stuff I checked previously.
Evap Fan: 0.5 Ohm, 120V when on
Defrost TStat: Closed (while on frosted pipe), measured <0.5 Ohm
Defrost Timer: motor spins, and turns compressor/evap fan on/off
Heater Element: 30 Ohm, 120V when on
Compressor Coils: (S-C)10 Ohm, (R-C)2.6Ohm, (S-R) 12.6Ohm
Start Relay: 4 Ohms
Overload: <1 Ohm
Condenser Fan blows when expected
I was about to overnight a defrost thermostat, but figured I'd ask around first.
It's obvious from the wiring that it has been replaced before.
I can only guess that the defrost t-stat has gone intermittent or the fan is intermittent.
I need to try and measure the voltages at the fan terminals the next time I find it stopped.
Any other thoughts?
cjaldous attached the following image(s):
cjaldous
#2 Posted : Tuesday, July 15, 2014 8:32:02 AM(UTC)
cjaldous
Update:
I caught the fridge "in the act." I came home to find the tops coils frozen, and the evaporator fan off.
The defrost thermostat measured open.
I'll be replacing that today.
cjaldous
#3 Posted : Wednesday, July 16, 2014 7:27:20 AM(UTC)
cjaldous
Update
I replaced the defrost thermostat yesterday evening and closed everything up.
I found the evap fan this morning still running (unlike the previous 3 mornings), but the freezer wasn't very cold.
I spot checked the walls with infrared and measured 34-35degF.
The fridge was reading about 45degF.
If it still isn't frozen by the time I get home, is it likely a compressor pumping issue?
I was told that if I had a freon leak it wouldn't cold at all.
