I woke up yesterday to find that my freezer was half thawed. The evaporator fan was not spinning. I opened the evaporator compartment and found the top portion iced up, but the fan could spin freely. After unplugging the fridge, and doing some troubleshooting (see below) I plugged the fridge back in and the fan started working. The freezer got cold enough to freeze ice, and everything seemed to be working. I woke up this morning to find the evap fan off again, the freezer half thawed, and the same iced up top coils. Here's the stuff I checked previously. Evap Fan: 0.5 Ohm, 120V when on Defrost TStat: Closed (while on frosted pipe), measured <0.5 Ohm Defrost Timer: motor spins, and turns compressor/evap fan on/off Heater Element: 30 Ohm, 120V when on Compressor Coils: (S-C)10 Ohm, (R-C)2.6Ohm, (S-R) 12.6Ohm Start Relay: 4 Ohms Overload: <1 Ohm Condenser Fan blows when expected I was about to overnight a defrost thermostat, but figured I'd ask around first. It's obvious from the wiring that it has been replaced before. I can only guess that the defrost t-stat has gone intermittent or the fan is intermittent. I need to try and measure the voltages at the fan terminals the next time I find it stopped. Any other thoughts? cjaldous attached the following image(s):
Update:
I caught the fridge "in the act." I came home to find the tops coils frozen, and the evaporator fan off. The defrost thermostat measured open.
I'll be replacing that today.
Update
I replaced the defrost thermostat yesterday evening and closed everything up. I found the evap fan this morning still running (unlike the previous 3 mornings), but the freezer wasn't very cold.
I spot checked the walls with infrared and measured 34-35degF. The fridge was reading about 45degF.
If it still isn't frozen by the time I get home, is it likely a compressor pumping issue? I was told that if I had a freon leak it wouldn't cold at all.
