brianosaur
#1 Posted : Monday, July 14, 2014 7:36:18 AM(UTC)
brianosaur
I am a hardwood floor contractor and one of my guys dented up a brand new range door of one of my customers. :mad: The owner is very reasonable :o, and I promised her I would replace the SS door panel.
I need to replace the panel for Samsung NE58F9500SS
5.8 cu. ft. Slide-in Electric Range NE58F9500SS | Samsung Home Appliances
Other sites list the part as "DG94-00901A" but I have yet found one with a diagram or photo of the part.
I believe it is this part but the Compatibility Tool says its the wrong one:
Samsung DG94-00901A Assy Door SUB;NE58F9710W - AppliancePartsPros.com
The only listed door panels I see are these:
http://www.appliancepartspros.c...-cooktop-oven-panel.html
Can anyone help me find the correct SS oven door panel, please?
Also is there a parts breakdown spec sheet available? :confused:
I've removed the panel on both my own ss wall oven & micro in the past, so I'm not completely unfamiliar with this type of repair. However, I would like to review the parts breakdown so as to easily know where & how to begin the repair when I get the the customers home.
Thanks :p
#2 Posted : Tuesday, July 15, 2014 2:32:44 AM(UTC)
Would be best to talk to the parts representatives at AppliancPartsPros.
They have more info and experience than folks on this forum.
