I am a hardwood floor contractor and one of my guys dented up a brand new range door of one of my customers. :mad: The owner is very reasonable :o, and I promised her I would replace the SS door panel. I need to replace the panel for Samsung NE58F9500SS 5.8 cu. ft. Slide-in Electric Range NE58F9500SS | Samsung Home AppliancesOther sites list the part as " DG94-00901A" but I have yet found one with a diagram or photo of the part. I believe it is this part but the Compatibility Tool says its the wrong one: Samsung DG94-00901A Assy Door SUB;NE58F9710W - AppliancePartsPros.comThe only listed door panels I see are these: http://www.appliancepartspros.c...-cooktop-oven-panel.htmlCan anyone help me find the correct SS oven door panel, please? Also is there a parts breakdown spec sheet available? :confused: I've removed the panel on both my own ss wall oven & micro in the past, so I'm not completely unfamiliar with this type of repair. However, I would like to review the parts breakdown so as to easily know where & how to begin the repair when I get the the customers home. Thanks :p
Would be best to talk to the parts representatives at AppliancPartsPros.
They have more info and experience than folks on this forum. |
THIS FORUM IS DEAD!!!!!!! |
