When I Turn My Dryer On, It Makes A Nois As If Its On But The Drum Is No Turning And When I Open The Door The It Is Not Heating Up Either. The Start Switch Is One That You Just Turn To On And Let Go And The Switch Then Goes Back To The Original Position. The Dryer Will Not Continue Sounding Like Its On Unless I Hold The Switch To The On Position.
Need Help. What Part Is Going Out?:)
THIS FORUM IS DEAD!!!!!!! |
