Serial No.- BA20306759
The fridge just isn't cold, the freezer seems OK though.
Thank you!!!!:)
Remove back freezer panel, if total, heavy frost, defrost and do a google search for the manual defrost procedure. If it goes in defrost, but no defrost action, probably a bad defrost thermostat clipped to the evaporator top.
THIS FORUM IS DEAD!!!!!!! |
I removed back panel and there is light frost on evaporator coil. The fan is working fine and the vent to lower section is not obstructed.
Thank you! ! 8 )
