JerryCaldwell
#1 Posted : Wednesday, June 11, 2014 8:23:40 AM(UTC)
JerryCaldwell
Serial No.- BA20306759
The fridge just isn't cold, the freezer seems OK though.
Thank you!!!!:)
#2 Posted : Thursday, June 12, 2014 1:35:00 AM(UTC)
Remove back freezer panel, if total, heavy frost, defrost and do a google search for the manual defrost procedure. If it goes in defrost, but no defrost action, probably a bad defrost thermostat clipped to the evaporator top.
#3 Posted : Thursday, June 12, 2014 1:35:19 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Frigidaire FRT18B4AW4 Refrigerator - AppliancePartsPros.com
Is the evaporator/freezer fan running?
It and the condenser/compressor fan should be on whenever the compressor is on.
JerryCaldwell
#4 Posted : Thursday, June 12, 2014 7:05:13 AM(UTC)
JerryCaldwell
I removed back panel and there is light frost on evaporator coil. The fan is working fine and the vent to lower section is not obstructed.
Thank you! ! 8 )
