2323FORU
#1 Posted : Friday, June 6, 2014 10:08:38 AM(UTC)
2323FORU
Need some help on the wiring for the heater coi, thermostat, and thermal cutoff. I took it apart and didn't pay close enough attention. The way I have it wired now is;
Thermal Cutoff Black wire - to Thermostat
Red wire - to machine
Thermostat Black wire - from Thermal cutoff
Red/white wire - to front
Front connection - Red/White wire - to thermostat
Red - to machine
Not sure if that is right or not. I know the front connections are right on that side but not sure about the rest of it. Any help is appreciated.
#2 Posted : Tuesday, June 10, 2014 3:16:29 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
