Need some help on the wiring for the heater coi, thermostat, and thermal cutoff. I took it apart and didn't pay close enough attention. The way I have it wired now is;
Thermal Cutoff Black wire - to Thermostat Red wire - to machine
Thermostat Black wire - from Thermal cutoff Red/white wire - to front
Front connection - Red/White wire - to thermostat Red - to machine
Not sure if that is right or not. I know the front connections are right on that side but not sure about the rest of it. Any help is appreciated.
THIS FORUM IS DEAD!!!!!!! |
