We moved into a new house with a dacor oven. I went to change the light bulb. I tried unscrewing the glass and when it would not budge I thought I needed to take out the screws. I did and when the housing dropped down I heard a pop and saw a flash. The fan started blowing and an f1 error appeared. We turned off the power and put it back together, but the fan and f1 error continue and neither oven will work. Do you have any suggestions? Thanks
I cannotr find any tech info on this unit.
But it sounds like you blew the control board. |
THIS FORUM IS DEAD!!!!!!! |
