JJLittle
#1 Posted : Sunday, June 1, 2014 10:55:56 AM(UTC)
JJLittle
:confused: My dryer is not drying anymore. I would like to try and trouble shoot and fix the dryer myself. Any ideas.
#2 Posted : Monday, June 2, 2014 2:06:32 AM(UTC)
Parts for Frigidaire LEQ2152ES0 Dryer - AppliancePartsPros.com
Need more info.
What works and what does not.
Have you checked the power.
If not then I would start there, the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
