:confused: My dryer is not drying anymore. I would like to try and trouble shoot and fix the dryer myself. Any ideas.
Here are your parts Parts for Frigidaire LEQ2152ES0 Dryer - AppliancePartsPros.comNeed more info. What works and what does not. Have you checked the power. If not then I would start there, the heater requires the full 240 volts. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. [COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
