colinas
#1 Posted : Thursday, October 22, 2009 11:14:27 AM(UTC)
colinas
Hello,
I would like to replace the turntable motor in a spacemaker XL1400 because it makes a weird noise (as if it was dephased). I have 2 possible candidates:
- square shape WB26X10037
- D-shape AP2024962
I guess I will find out when the motor will be removed. But I'm not sure how difficult the task will be.
The diagram shows that I shoud remove the bottom with the grease filters and lights: Replacement parts for GE JVM1440WD001 | AppliancePartsPros.com
And what should I expect then? A direct access to the motor?
